Tinyandthegang
Jan 05, 2018Explorer
They worked prior to the seller changing the chassis battery and that is why I believe that they need to be re calibrated prior to use,,I just can not find any information on them anywhere,,I had hoped the technician at camping world would be able to re calibrate them..Thank you for your searches and your time invested in my problem,,I do appreciate your efforts greatly...ted
If they worked prior to a battery change then I would suspect a wire was not reconnected.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
