Hi DonBry12 welcome to the forum. Your title says Power problem for fridge and AC. Are both your refrigerator and your air conditioner not working? Or are you saying the refrigerator is not working when you are plugged in to AC (shore power)
If both the AC and refrigerator are not working I would look into the breaker panel. Also try unplugging the refrigerator from wherever it's plugged in, and use a known good load like a lamp to plug into the same outlet and see if there is power.
Assuming you mean refrigerator only, what is the make and model of the refrigerator? I would look just inside the door for a sticker with hat information. When you say not working do any lights or LED's illuminate and it just doesn't get cold? Or do the lights work and it doesn't get cold?
Thanks and hopefully we can help yo figure it out.
- DonBry12Mar 01, 2024Explorer
Thanks for helping. Neither the AC nor fridge are getting power. I’ll try resetting the fridge. No power to thermostat.
- opnspacesMar 01, 2024Navigator III
Unless your RV is really old, the refrigerator is plugged into a wall outlet somewhere. How do you know that there is power at that outlet?
