Currently reading manual but thought I would post on here for additional help. 2004 Itasca Suncruiser. The problem: Plugged in at house, breakers good, Hugh's Autoformer light shows good pow...
Is your rig a fifty amp or 30 amp shore power? Could try turning off all circuit breakers applying light pressure toward off, then turn breakers on one at a time staring with the main, then each branch breaker one at a time. Are you using an adapter for connection to house? It could be bad.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
