Alan_Hepburn wrote:
fj12ryder wrote:
He did clarify that the RV plug end was what was correct, but that was the only link he could find that showed a 30amp RV plug end, so the 50 amp pedestal plug is not relevant. And Bobbo showed a 50 amp plug diagram which also would be irrelevant.
The first photo clearly shows a 50A female receptacle; the cord that Bobbo showed is also a 50A cord, as clearly marked on the connector. The connector end with the 3 holes is a typical Marinco connector - the ground connection is a copper plate on the side of the connector (facing away from the camera) as has already been noted above (twice).
Absolutely, I am totally out to lunch on this. I know better but there was a short between eyes and brain. I should have caught it when Bobbo said something, but I was definitely out to lunch.
