Sean_Boburk's avatar
Sean_Boburk
Power problems
Not my RV...helping a lady.
Gal has a 5th wheel...she had a retired electrician wire in a 50 amp jack for it at her house. She "said" that it worked for awhile, and does not now. Also said that he wired something wrong at first and "popped" the power. NO idea if that means it popped the house breaker, or popped a breaker in the RV.
Checked for power at the plug that hooks to the RV power jack. The two L shaped sockets have 120 volts to the non L shaped socket, and have 120 volts to the contact on the side of the plug. I did NOT check L shaped socket to L shaped socket. If I do...these should read a relative zero volts correct? 240 volts would be wrong, correct?
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
