valhalla360
Jul 28, 2021Navigator
It's a common problem, particularly at older parks.
1) Get a voltage meter. No point fixing something that isn't the problem. I suggest getting one that plugs into an outlet full time and put it where you can see it frequently.
2) Solar is a separate subject and largely irrelevant to if your park has low voltage.
Assuming you do have low voltage, there are some options:
- Pick up an Autoformer (google it). These devices will boost voltage by 10%. They aren't a cure all (if the pedestal is at 80v...that's still going to leave the air/con seeing only 88v) but it will avoid a lot of marginal voltage issues.
- Switch as much as you can over to propane. So the fridge and particularly the water heater. The more amps you are drawing, the more it pulls the voltage down. If it's only one hot afternoon, you could turn off the battery charger but then you have to remember to turn it back on later.
- The final solution is picking up a generator. I would suggest looking for one at least in the 3000w range. You can make some smaller ones sometimes work but it's really marginal. Some will say the campground won't allow it but we've had good luck telling them to provide the 120v power we contracted for...and they have always backed down.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
