valhalla360
Jul 28, 2021Navigator
theoldwizard1 wrote:
Some careful research MIGHT locate an inverter that will ADD power to your circuits ! Then a good solar and battery setup would be another solution.
They do have inverters that can merge with shore power but MOST inverters don't and the ones that do are expensive.
You CAN'T simply wire the inverter into the shore power circuit simultaneous with the shore power cable. It needs electronics that line up the sine waves or you can cause major problems.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
