time2roll
Jul 28, 2021Nomad
ryankenn wrote:Is that #12 wire feeding what service? 20, 30, 50 amps? Is the RV 30 amps?
I haven't had my meter on it yet but you can tell by the sounds of the fans or AC that either the voltage droops badly or the run on the 12 wire from the looks of it is so long current isn't being delivered as fast as its demanded. Depending on neighboring usage fans will start slow and ramp up.
Yes put a voltmeter on the supply before you plug in and again with a few items running.
Are you willing to go without A/C?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
