time2roll
Aug 28, 2021Nomad
Lynnmor wrote:Possibly two autoformers will be needed.
An autoformer will boost 10%, your 100 volts will become 110. Since 108 volts should be considered the minimum, I would bet that there will be times when your boosted voltage will drop below that.
My Franks booster goes 16% in two stages and has worked fine when needed. Only one place near Glacier NP was the voltage too low to boost until sundown and the other air conditioners started cycling.
