Dave_H_M's avatar
Dave_H_M
Explorer II
Apr 23, 2017
Power Source For Dometic Vent Fan
I am installing a vent fan on the outside/top of the frige venting system.
I would like for the fan to be energized any time the frige is on. However I am at a loss for the power source.
Anyone do this and have a recommended place in the rear of the frige to tap into 12 V power that will be energized only when the frige is on.
thanx
  • Yep- J2 should work fine. On some models, that lead splits in 2, some even have a quick connect twofer, which is how I would hook it up- make a twofer with wire and quick connects.
  • thanks Chris :S it is a 2862.
    I looked at the lettering on the back of the black box and it does not show a J3
    So it looks like I open that up and hook into the J2 circuit. And since it shows a fuse there, I am going to go without an inline fuse.
    I would appreciate if you would give me a shout back on my intentions. Am going to wait until tomorrow to make the final power hook up. Dave
  • Depending on which model you have, and which board is actually installed, it will be J2 or J3 on the board- J2 usually runs to the interior lamp, J3, if it has it, is for fans, heat tape, etc.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
