ricelake922's avatar
ricelake922
power steering cooler
The power steering coolant on my 1996 Monaco Dynasty is leaking. It has a road master chassis and I truly cannot find a replacement. It is 2" wide by 4" high and 4' long. I have contacted Monaco and they cannot assist. Any one please have any ideas?
  • JaxDad's avatar
    JaxDad
    Explorer III
    Those coolers don't generally fail, usually it's a small crack or pinhole from some road debris.
    Find a good high-end welding shop or hydraulics shop. Either one can fin and TIG weld the hole.
    I'd start with a hydraulics shop in case it's just a failed O-ring or fitting / hose union.
  • Your out of my league on this one. But I question if you have power steering coolant. I would suspect you are leaking power steering fluid from the power steering cooler. If that's the case you might be able to use a cooler made as a transmission add-on cooler to replace the leaking unit. Just my thoughts. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
