Can someone tell me if while parked, and you are listening to the dash radio with the ignition key on, does it prevent the tv from working off 12 volt dc power? On my motorhome, a 2008 Tioga 31M, the ...
After rereading your original post, is your TV working from a 12V outlet?? Usually the lockout is only on a 110v circuit. for a 12V outlet, the only way the ignition would effect it is if it is wired into the accessory circuit.
