Livies_Dad's avatar
Livies_Dad
power window doesnt work
05 ford e450 Class C--Power window on passenger side wont work.
Doesnt work off master switch or switch at passenger door. Does not even click. I would guess there is only two things- switch or motor.
Drivers side window works fine. My question is -how do you get the door panel off?
Any help appreciated.
  • Try researching the issue on Ford-trucks.com. I seem to remember seeing posts about this and the issue being dirty contacts on the control unit (driver's door).
  • I would suggest taking it to a service center. The new windows are as simple as putting it back on a track. You usually have to replace the entire assembly.
    UNLESS it is just a fuse. Look in the fuse box diagram for one that says passenger window.
    Try pulling up on the panel, once you have the bolts out.
