Naio's avatar
Naio
Explorer II
Aug 29, 2016
Powered solar panel tilt?
Are any of you doing this?
I was thinking of, for example, the setups used for automatically opening greenhouse windows. (Those would be AC, though.)
Also, the panel tilt brackets I've seen on this forum seem to tilt in only one direction. I often don't have a choice in which direction to face my rig. Anybody doing a multi tilt?
  • Naio's avatar
    Naio
    Explorer II
    smkettner wrote:
    When the electric tilt is half the price of the panel I will have some interest.
    Hmmm... I see what you mean by prices.
    Looking, I found these fascinating little items. Actuators that operate by expanding when warm, and you can adjust at what temperature they move how far. Lift up to 33lbs and 18 inches. And cheap!
    Maybe not applicable to an RV that moves a lot -- you'd have to adjust them each time you camped at a new altitude or closer to water or whatever. But maybe useful if one were staying in the same place for a while. I just figured I'd post them and maybe someone will find a use :B.
  • When the electric tilt is half the price of the panel I will have some interest.
  • Almot wrote:
    Naio, fewer and fewer people use any tilt at all, these days.
    ..because we're getting older and older.
    The Q always has a power-tilt vendor on Kuehn St.
  • Most all tiltable panels will tilt either way, depending which side the bars are placed. 4 way tilt requires more hardware.
    Power tilt has been available for a long time. But will cost a lot more than adding the panels that will make up for it.
  • Almot's avatar
    Almot
    Explorer III
    Naio, fewer and fewer people use any tilt at all, these days. It's easier to get more flat panel wattage instead.
    Don't recall any powered solutions here.
    Westend has 4-way tilting - not powered.
  • I can tilt either way with these. I face E or W. Pay no attention to that big shadow.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
