Taxman2004
Jul 06, 2016Explorer
I've got an LCI automatic leveler on my 2014 Itasca Solie DP. Many times after retracting the levelers I get a Low Voltage message on my electronic display. Freightliner Custom Chassis told me that that means at some time during the operation of the levelers the battery power went below 11.9 amps. I only get the message once because the batteries get charged up. Suggest you make sure your house batteries are up to charge. If so, is there a loose wire to the leveler control. On my 2005 Terra the fluid reservoir was in the front engine compartment in front of the passenger. It had the Ford V-10 engine. Good Luck.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
