MEXICOWANDERER
Sep 03, 2013Explorer
Starter jumper battery thingee NOT big enough to use with humidifier period. Too much draw. You can purchase a l-o-n-g cigarette lighter extension cord. I recommend grafting 16 gauge wire to lengthen to your bed if necessary. Travel trailers can tap into the light switch. Been done a hundred times if it's been done once. DO NOT LEAVE THE UNIT CONNECTED when charging the battery with anything else except the rig's converter. Unplug when engine running.
