Ed_Gee
Jan 29, 2015Explorer II
If you would better describe what those " 10 Watt LED chips " are, it might be easier to figure out just what you are trying to do or work with. Most RV LED modules I have worked with are plug and play....no extra circuitry needed. And arrays of LEDs generally work right off the RV 12VDC supply. I have 35 years as a Sr. Telecomm. Technician yet can't figure out quite what you want or have there.
I would not expect an LM7809 to safely regulate a 10Watt load, if that's any help. Also, what the heck is your " 5 amp 90 volt power supply " supposed to do???
edit. After re-reading the original post it appears you got some non-RV specific LED arrays that work off 10 volts. Given the efforts to work around the 10 volt limitation, wouldn't it just be more cost effective to obtain a couple high Lumen output LEDs that were designed for 12Volt RV use instead of acquiring and building all the necessary power regulation to get around that?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
