MEXICOWANDERER's avatar
Jan 29, 2015
Powering My New LED 10-Volt 10-watt R.V. Lights
12 Volts over-drives the chips by a bunch.
Three diodes in series in a PITA. I have a bunch of LM7809 regulators. With a silicon rectifier biasing the negative...or not.
Can this regulator survive driving a pair of 10-watt LED chips? If I do not bias the regulator it would mean driving the chips at 9 volts.
I am purchasing a 5 amp 90-volt power supply tomorrow. But I need heat sinks right away. If I can double up on the chips per heat sink, and use a fan for cooling, then I will save valuable mounting space. It isn't the 7809 it is the extra 7809 heat sink per the added 10-watt chip that's a killer to my plans.
20 watt chips use a weird 28 volt supply.
A single 10 watt chip is not enough light and at twelve dollars a pop the fan+heat sinks add up fast.
Yes I am getting old and I need "blindingly bright" light to see well.
Forum members familiar with the LM7809 may also be familiar with what I can get away with. And what I cannot.
Thank You
