DrewE
Dec 07, 2015Explorer III
RDMueller wrote:MEXICOWANDERER wrote:
Check out these plugs and sockets
WEATHERPAC
Twin connectors allow the use of 12 gauge wire which is plenty for the DROK. Mix & match with smaller gauge wire fittings.
Best of all, the Weatherpac connectors are KEYED so reverse polarity is impossible. They are WATERPROOF, and a simple latch snap keeps them from slipping apart like Anderson Pole Connectors do. There is no FIGHTING the terminals or connections, either.
Use the female socket on the power source (converter - power supply) and the make plug on the load (meters, etc).
http://www.delcity.net/store/Weather-Pack-Male-Housing/p_809144.h_809147.t_1
This will start you out. You will need the other side of the connector, plus
Corresponding terminal pins
Corresponding silicone seals for the wire
This is top quality stuff, made to last for decades.
These are exactly the kind of plugs I've been looking for. I looked at some of the stuff they were selling at the local auto parts store but didn't find anything I liked. These will be perfect. Thanks!
If you want a nice starter kit, this appears to me to be a good deal.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
