scrubjaysnest
Feb 07, 2016Explorer
RoyB wrote:
This is what PROGRESSIVE Dynamics states in their operating manual on how long it takes to charge a battery using the DC VOLTAGEs listed below:
"Progressive Dynamics ran this test on the amount of time it took a PD9155 (55-amp) converter/charger set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
13.6-VOLTS (Normal Mode) – Required 40-hours to return the battery to 90% of full charge and 78-hours to reach full charge.
13.2-VOLTS (Storage Mode) – Required 60-hours to return the battery to 90% of full charge and 100-hours to reach full charge."
This is based on having 17-20AMPS DC current available for each battery in your battery bank being charged... NOTE That Progressive Dynamics doesn't even list using DC Charge Voltages around the 12.0VC range as this would take alot more than 100 hours to achieve a 90% or 100% charge state.
My PD9260C Smart Mode converter/charger follows this report pretty close when providing 120VAC to the unit running from my 2KW Generator when camping off the power grid.
Roy Ken
Interesting, I guess normal mode here is what the battery industry call absorb mode. FLA's per most battery makers want 14.8 volts absorb vs AGM's that seem to like 14.4 volts.
Storage mode I guess is what the battery industry calls float mode.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
