The only other place where I can connect the tv is to a 12 volt receptable on the dash, but I don't want wires hanging all over. The DVD player is 110 VAC, and it also would require an extension, which I also don't want. Other folks have disabled the tv lock out by taking out a single wire. I have a wiring diagram for the PowerTek, which shows two 12 volt wires (brown) going into what I believe is the relay, which are labeled on the diagram as "ignition signal," which like I said, are now disconnected. That should have disabled any connection between activation of the ignition switch and the receptacle, but it did not. There is also a 110 VAC going to the solenoid (black), but I don't want to mess with that. Anyone who has done this, can you help?
