wa8yxm
Aug 11, 2015Explorer III
path1 wrote:
My pressure relief valve is leaking at water heater at home, but has same type set up like RV. Do these valves go bad and I can just replace the valve? Water still gets hot. The water heater is old so not surprised I valve doing its thing is because tank is shot.
What do you think I should do to trouble shoot?
Yes, and yes, Be sure to turn the water heater off and RELEASE PRESSURE, in fact you mnight wish to hook a hose up to the tank drain and route to a floor drain to drain it while you replace the valve.d
NOTE ALSO... If your house has "CITY WATER" often this can be 80PSI or more (112 PSI in one RV park I visit) this can be enough to upset the TPR valve.. the P part.. Check your water pressure and if needed post for a suggestion or contact a professional (Some hardware stores have good consultants) .
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
