MEXICOWANDERER
Feb 01, 2014Explorer
Kudos to Generator Jim!
There are special electrical cleaner lubricants just itching to be sprayed into a DISCONNECTED relay or contactor, after following Generator Jim's excellent advice.
The light lube keeps pivot points lubricated.
I would UNSCREW and VISUALLY CHECK each wire, one-at-a-time, plus look inside the screw clamp, reattach, tighten the screw then DOUBLE CHECK the tightness of all screws. One more check a month later unless the manufacturer decided to hide the transfer switch atop the black water tank.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
