mlh
Jun 29, 2015Explorer
Very Expensive Preventative Maintenance
For anyone that will be replacing the drive belt on a Ford V-10 anytime soon: If you happen to remove all the plastic trim and air filter housing, etc., please be aware of how you put it back together.  I recently took a trip and when I got on the highway, I hardly had any power.  I could barely get to 60 and could not muster up enough speed or acceleration to pass anyone.  I would slow down considerably on overpasses.  I unhooked the Jeep to see if it improved.  It didn't.  I figured it must have been the fuel filter.  I stopped at the nearest Auto Zone and they sold me a fuel filter for a 2010 E 450.  I get out in the parking lot and could not find it.  I checked the manual and it said that the filter was located in the tank.  I guess the guys at Auto Zone didn't know that.  I went back inside and returned it.  Got it home and ordered a new fuel pump assembly since you can't order just the filter.  Dropped the tank, replaced the assembly and back together.  This was not an easy task by the way.  I let it get down to a quarter tank.  I can't imagine if it had been full.  Anyway, I took it on a test run.  It seemed better, but not much.  I got out on the highway and things did not improve.  I pulled over to disconnect the battery to see if resetting the computer would help.  While the battery was disconnected, I decided to check the air filter just in case although I had recently replaced it.  I removed the first section of the housing.  When I went to put it back on, it would not go on quite right.  There was a flap that was positioned the wrong way almost blocking the entire intake.  I corrected the flap, reassembled everything and got back on the road.  It ran perfect.  Oh well.  At least I have a new fuel pump that should last me for quite a while now.
