Homeless_by_Cho
Jun 11, 2017Explorer
Snowman9000 wrote:romore wrote:
You can open the drain valve until clear fresh gas comes out, close it then pull normally.
Are you sure? It has a fuel pump. I would think the only way is to pull and pull. Other than to pressurize the tank, or to squirt a little some into the carb inlet.
I don't think so either. I put the engine switch in the ON position, leave the fuel cap vent lever in the OFF position, and shake or rock the gen set side to side vigorously for about 10 seconds. This rocking causes the gas to expand and push itself into the carburetor. Now turn the fuel cap vent lever to the ON positions, set the CHOKE to FULL ON and PULL once; Wait 10 seconds, PULL again. Mine usually starts. If not wait another 10 seconds and PULL again.
LeRoy
Edit: I noted that the engine switch needs to be in the ON position while shaking the gen set.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
