NinerBikes
Jun 14, 2017Explorer
I don't care which model you have. Unless you live out in the boonies, and non city areas and KNOW you are getting and buying ethanol free gasoline, drain the carb bowl of all fuel, leave the switch for fuel and spark on the "off" position, turn on the choke, leave it on, and pull the starter cord 4 or 5 times, to suck all the fuel out of the jets, before storage.
If you want to start it up easily, leave the top vent in the closed position, turn the switch to the "ON" position, rock the motor back and forth 3 or 4 times, wait 10 seconds, then pull the starter cord, with the choke on. I always start in "eco" mode on. Once running, open up the vent to the "on" position on the fuel cap, let it warm up for 120 seconds, then plug in what you want to run.
I always warm my motor up before putting it under any load. Common sense.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
