ItsyRV
Sep 23, 2019Explorer
The primary difference is the RV formulation is stable. It's designed to be seen so it will not "color change" over time. Additionally, it is also formulated to maintain it's properties in all forms of movement where the regular version can tolerate movement but probably not the same as you get with an RV traveling down a road in a storm. Depending on the application, you may also want to check into the Geocel 2300 MHRV.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
