cannesdo's avatar
cannesdo
[Problem Solved] A/C and ceiling fans not working....
Checked the switches, nothing thrown. Turned it off and back on (on 50 amp) at the post. TV and lights working, outlets working. But none of the fuses in the panel are lighting up.
Only thing I did today was put my space heater outside to try to help dry out my truck's air filter, plugged into the outside outlet. No problem. Switched to the hair dryer in the outside plug. No problems there either. Just tried to turn on the air and no reponse.
Any ideas?
Thanks....
  • Look at your outlets. Look for a tripped GFI outlet. They are commonly found in bathroom or near water source in trailer. They will have a reset button on them. Good luck.
