MrWizard
May 31, 2016Moderator
start here
you don't have a separate converter
unplug from shore power turn inverter off
check battery
your battery is dead, and the charge section of your magnum is not supplying enough power for the lights etc, the 12v shuts off when you try to turn something on, a total reset might fix the magnum, but if it don't then you will need to replace it,
disconnect and test the battery, do you have a backup stand alone battery charger you can charge the battery with
Magnum Energy Inverter/Charger model MS2000
check battery
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
