Tim-n-Deb
May 31, 2016Explorer
After I wrote this post, I went about checking all that I could. 1st thing checked: Batteries and cables. The terminals were dirty so started taking each one apart to clean and reassemble. About the fifth terminal in, the cable just fell off from the battery post. The cable lug was eaten through so it was just touching the ring part on the battery post. Finished cleaning the rest, replaced the terminal lug and reassembled. Turned on all power and now ALL is working as should! I guess it does pay to check the easy and obvious stuff first. Thanks for your help.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
