JBarca
Nov 24, 2022Nomad II
larry cad wrote:
Friend of mine has a class C with a Dometic frig not working. We did some investigating yesterday, and found the following:
Propane flame works when in that mode
Electric heat works when in that mode
Frig temperature doesn't change in either mode and stays constantly at 51
My conclusion is the frig is broke and needs a new cooling unit, or am I missing something?
Maybe try this first. It can be hard to conclude that no cooling on gas or electric is the cooling coil. It might be, but there are other things that can cause that issue a lot cheaper to fix.
Try these:
With fridge off,
Go outside and take the lower vent side panel off. Sniff and look for yellow residue near the gas burner area. You may have to remove a shield but you need to see the gas burner with no cover on it if yellow stuff is not yet visible. If there is residue, the cooling coil has a leak and it may smell like ammonia. If there is no yellow residue and no strong smells after seeing the gas burner, then try this next step as leaks do happen in other areas but maybe more often in the gas burner area. The last one I dealt with where the coil went out, I had to remove the gas burner shield and then saw it.
If no yellow stuff yet, then turn on fridge on electric, or gas, make sure the light inside the fridge works and the control lights are on for normal. No lights that is a problem.
Go outside and look at the gas burner area again, if on gas, is the burner lit and the system heating? If on electric, you may have to wait 1/2 hr and then gently feel for heat on the boiler sheet metal, is it getting hot?
If you have no heating in the boiler area on gas or electric, then there is a controller issue as problem one. You then have to back into why.
If it is heating, after about 3 hours of running, the inside temp should be dropping. Confirm this with a thermometer inside the fridge from when it started until the end of the 3 hr period. There should be some good level of temp drop.
If it has been heating constant for 3 hours and nothing happens to drop the temp inside, not even 5 degrees, then this points to the cooling coil.
Hope this helps
John
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
