CT_WANDERER's avatar
CT_WANDERER
Problem With Dometic Refrig Model 2862 UPDATE
My Dometic refrig model #2862 faulted out on gas today. Tried to reset it. Will not run on gas. OK on electric. I wanted to check the gap on the electrode. Removed it to clean and check gap the electrode wire is lose. The spark end. It move inside it insulated housing. Is that normal? I thought it would be tight and you would have to bend the electrode wire to get your gap setting. I can hear a click when it tries to start but no flame. I have gas, the stove and water heater works and battery power is good plugged into shore power. Time for new electrode? Thanks Gary
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
