Old-Biscuit
Jul 11, 2018Explorer III
pianotuna wrote:
On mine there was a relay. During the course of disassembly the relay started working again. The switch inside the RV was, on mine, 12 volt.
It took 90 minutes--and I did replace the element since that is what I thought had gone bad. They sure as heck did not make it easy to be serviced.
That sounds like an Atwood water heater.DC Relay and element on backside of tank
Suburban has a similar model...."DEL"....uses DC Relay but element is easy to access in outside compartment
OP has a "DE" model....direct 120V AC to element
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
