Old-Biscuit
Jul 11, 2018Explorer III
bob213 wrote:
I haven't checked for power at the t'stat. I have a #232306 t'stat. That is correct for 120v..right? Gas side works fine. I have pushed reset without success. Wire shows burned spot but is intact. I will check for power tomorrow and replace if none there. One lead to black wire and ground other like I did for switch?
Yes and Yes
With switch ON top black wire should be hot (bad switch if not)
Then with water temp cold (below 100*F) the bottom wire will be hot if t-stats are closed
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
