bob213
Jul 12, 2018Explorer
Old-Biscuit wrote:
With switch ON top black wire should be hot (bad switch if not)
Then with water temp cold (below 100*F) the bottom wire will be hot if t-stats are closed
Just a follow-up.
With switch on I had power to bottom NOT top of t'stat. Replaced t'stat and now have power to top and bottom. Did factory wire it backwards? It's worked that way for 4 years.
Do I need to switch wires?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
