gadabout's avatar
gadabout
Problem with LED tail lights for toad
i bought a couple of round LED tailights from Harbor Freight (I know!), and cannot get them to work with my wiring. I have separate bulbs installed in the tailights, and they work fine, but I want a bar with the LEDS because of the improved brightness. I can apply 12v & they illuminate, but when I connect them to the toad wiring, nothing. Is there some interface that I need? Thanks...Hal
  • While the quality of the tail lights may not be the best they are usually adequate. I bought a set of HF mag base lights for spares in case something happened to my incandescent set and had nothing but trouble with them. I was on the road and decided to fix them if I could instead of returning them when I got home. They were mis-wired. Now that I rewired them, no problems.
    Try mikeh449's suggestion and reverse the leads, if that works maybe your ad on lights have the wires reversed.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
