ksg5000
Jul 29, 2016Explorer II
If it were me I would loosen the front cap railing (one that holds down the roof membrane) - repossession the membrane - tighten the cap back down - caulk it appropriately and probably apply a six inch layer of Eternabond. I would likely also put Eternabond on the side edges as well as the rear cap. Eternabond is a good fix for most leak issues - lots of threads on the subject - do the proper prep work b4 applying.
Ripples are common with rubber roofs - wouldn't be concerned about that much - your focus should be on potential sources of water intrusion (hence sealing the caps/edges).
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
