CarnationSailor
Jul 29, 2016Nomad
DownTheAvenue wrote:
Sounds like the glue holding the membrane to the roof underlayment has been compromised. Without the glue holding the membrane to the underlayment, any repairs will be temporary at best, and ultimately, the membrane will work loose again.
I have to wonder if the OP had washed the roof with unapproved solutions causing the glue to dissolve. This is a known problem and is well documented. The membrane manufacturer probably has a list of approved solutions in their owner's manuals.
You can stop wondering.
I only used Dicor cleaner and Dicor UV protectant.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
