spadoctor
Sep 06, 2013Explorer II
open the door and look at the upper right hand corner. You will see (2) 1/4" hex screws....unscrew each a couple turns and retighten. This is the point that the ground is attached inside....if the ground anywhere is poor it will not see the needed signal voltage and turn the gas valve off. Also a ground wire added between solenoid ground wire to the burner screw helps with eliminating delayed ignition.
