KD4UPL
Dec 07, 2016Explorer II
I find it hard to believe that voltage drop will be an issue for you at all. Running 16 amps thru 1 run of #10 for 25 is well under 2% voltage drop at 60 volts.
Simply install a DC rated breaker in the wire between your panels and the CC.
2OM, 120v is lethal as well. Anything over 50 volts is considered potential lethal. But yes, DC is worse as it's constant flow causes muscles to lock making it harder for the victim to let go.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
