red31
Dec 08, 2016Explorer
EsoxLucius wrote:time2roll wrote:
http://www.genuinedealz.com/voltage-drop-calculator
This is a inadequate voltage drop calculator. You need to be able to specify actual/rated voltage output, not nominal voltage output.
Nope, the voltage drop is the same, one only needs to calculate the % based on actual voltage.
1v for 12v seems to be more than 1 v for 60v, the math be simple.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
