nvreloader
Dec 31, 2016Explorer
Thanks guys
I don't know which way I'll go just yet,
until I make sure I have all the bases covered.
Question,
If I use the OEM PD 9260c charger to charge the 4-6v batteries,
how do I get the 2-90w tongue batteries charged?
These tongue batteries start the gen set, which need to be also charged.
There is 2 (Red/White) #10 wires that run from the PD 9260c charger to the 2 tongue batteries, with a total of 21' run length, as a OEM setup, then go to the gen set for starting it.
This OEM wiring setup seems sadly lacking, as It takes several hours,
to barely get these tongue batteries recharged, after a nights use of furnace use, IMHO.
Per the PD install manual, the largest size of wires it will accept is #2.
Can I tie these 2- #10 wires into the the NEW inverter wires, (for charging the 2 tongue battery's) using the largest possible to reduce wire loss from the battery's for the inverter install? :@
Tia,
Don
Question,
Tia,
Don
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
