CT_WANDERER
Jan 02, 2017Explorer
nvreloader wrote:
WE
Thank you,
Your info explains a lot to me.
I now get the picture, very outstanding build in the CH.
I will sit down and draw up something similar for my build,
as space/room is kinda tight, in my electrical bay etc.
Question,
I see you both a inverter and converter, (in your install),
don't they both DO the same thing, depending on which power source is being used,
convert or invert, either or AC/DC power to another power type?
Slightly confused again, :@ with this terminology.
Tia,
Don
A converter takes AC to DC to run your DC system and charge batteries. The inverter takes DC to AC to run you standard electric equipment. Then you have Converter/Inverter which does both jobs. This is a very simple explanation.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
