CA_Traveler
Jan 06, 2017Explorer III
nvreloader wrote:
Thanks Guys
I have the OEM installed PD 9260c DC converter only, from the past use of this charger, I have my doubts about this charger to reliably charge the new 4-6v 440a battery bank, as it seems to have a very hard time recharging the 2-90w Deep cycle tongue battery's, but I am NOT sure I am using it correctly, with the Wizard attachment etc.
Probably the wiring.
Since I also have the MS MPPT 60a solar CC for charging the new battery bank,
will there be any problems using the Mag 2012 inverter/charger in my new system?
No
I am NOT sure how these 2 pc's of equipment (MS MPPT/Magnum) will work together etc.
No problem.
I do NOT know how they will interact with each other etc.
I do, no problem.
But why the big concern? Unless your solar is very large the Magnum will be doing the major charging with the gen which likely won't happen when you're out wandering around chasing game.
Of course if you're planning on a auto start gen then why have solar?
Tia,
Don
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
