nvreloader
Jan 12, 2017Explorer
Don
Thanks for the info.
I am going to disconnect the TH from the shop plug in, TH has been on shop power (electrical) for the last 60+ days, so the battery's should be back to full charge?
I'll set the TH thermostat at it's lowest setting of 55* and then let it run for the night, 10/12 hrs time, (temps are around 20*).
Then I'll fire up the gen set and run it for a while, which will run the PD charger to recharge the 2-90w tongue battery's,
I'll take some reading at the charger end and then go to the battery ends and take another set of readings, of the 21' run of #10 wiring, at the same time.
This info will give me just what the OEM PD 9260c charger is putting out to the battery's during the normal use.
I'll post the end results.
Tia,
Don
Tia,
Don
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
