ScottG
Aug 05, 2014Nomad
You should be able to do what your doing if everything is perfect. But if the 30A receptacle is a bit worn (normal) or there's wear in any other connection, you'll get heat.
Because of this I suggest you turn the WH over to gas and run no other heavy loads while using the AC.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
