RJsfishin
Jan 30, 2016Explorer
Just ignore the chart posted in the previous,... does not even show a 3 ft one way run.
A 3 ft run chart actually shows 12 ga to be more than adequate for 65 amps, but your 10 is just perfect.
I would recommend a PD 9260, w/ the Pendant Control that lets you manually choose which of the 3 stages you want to charge at, letting you force the bulk charge rate of 14.4 any time you want, for faster charging. Some times the Pendant comes w/ the converter, sometimes it is $12 extra.
I myself charge w/ a 1000w Honda, which is limited to the PD 9245,...which still charges quite fast.
DieselBurps wrote:
RJsfishin what would you recommend? I will be charging with a 2000 watt Yamaha genny.
