Salvo
Jan 31, 2016Explorer
If you're on generator then the PD is not the optimal choice. It will never output rated current. Gen time will be longer. You're already having that problem with the Boondocker.
Here's a charging plot of two Costco 6Vs. The Iota outputs 55A from the get go. At 87% SOC the Iota drops out of boost. At this point in time solar can finish up the job.
Voltage scale is on the left side y-axis and current & SOC scale are on the right side y-axis.
