NinerBikes
Feb 02, 2016Explorer
DieselBurps wrote:
I don't think the solar is throwing off the "boondocker" converter since it doesn't seem to change how much amps or volts I get out of it if the sun is shinning or not.
I am still waiting to hear back from Randy, will probably have to try calling again once some of this snow melts. If he warranties it I will probably go with a progresive or Iota converter. The only issue I am not sure about is my boondocker is a converter powercenter meaning it has the fuse panel built into it.
I will end up getting some sort of a manual charger regardless since I think I prefer that and like the control it gives me. Which Meanwell should I be looking at for my 2000 watt genny?
Why don't you disconnect your solar from your batteries, and just try charging with the Boondocker, and measure and see what the results are, instead of assuming?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
