DieselBurps
Feb 13, 2016Explorer
Well no word from Randy at BestConverters.com. I think I am done with them and their 'smart' chargers. Moving onto a meanwell. Now I need to know which one to get for my needs.
My plan is to just use the powermax boondocker for when I have shore power and for float, when I am boondocking I need to charge as much and as fast as possible with the least amount of genny run time. I do have 250 watts of solar, and a DC compressor fridge that draws 3.8 amps when running.the batteries are Costco 6 volts. I think I will mount the Meanwell inside the camper attached to the batteries with a cord for the AC side that will come out where 30 amp shore cable is located. My questions are as follows.
Which Meanwell for a Yamaha 2000 watt genny?
RSP-500-15 ?? or RSP 750-15 ??
Set voltage to 14.8 coming out of the meanwell to the batteries?
what size wire for run from Meanwell to batteries? Will be about 3 feet away.
Thank you all!
Thank you all!
